Due to high customer demand, Alphacool is expanding its Special White Edition and now also offers the Rise Aurora fans in white. The fans perfectly match the white NexXxos radiators and the connectors of the Eizapfen White Edition in terms of color. The digital aRGBs create a unique illumination to complete the visual appearance.
Alphacool's Rise Aurora doesn't just score points for its design, though. Like the model in black, the fan is offered in 120mm or 140mm. Due to the high airflow (120mm 154.1 m³/h | 140mm 154.1 m³/h) paired with a high static pressure (120mm 3.17 mm/H₂O | 140mm 2.20 mm/H₂O), the fan is perfect for mounting on radiators of a water cooling system or for ventilating a case.
Other plus points are the wide PWM controllable control range (e.g. 0-2500 rpm for the 120mm variant) as well as the decouplers on the frame and the tear-off edges on the fan blades, which make the Rise Aurora the perfect choice for a silently operated case or water cooling system.
Technical data fan | Rise Aurora 120mm | Rise Aurora 140mm |
L x W x H | 120 x 120 x 25mm | 140 x 140 x 25mm |
RPM | 0-2500 rpm (+/-10%) | 0-2000 rpm (+/-10%) |
Bearing | Sleeve Bearing | Sleeve Bearing |
Connection | 4-Pin PWM | 4-Pin PWM |
Voltage | 12V DC | 12V DC |
Power consumption | 8,64 Watt (max) | 6,60 Watt (max) |
Current consumption | 0,65A (0.72A max) | 0,50A (0.55A max) |
Static pressure | 3,17 mm/H2O | 2,20 mm/H2O |
Max. air flow | 118,9 m³/h | 154,1 m³/h |
Noise | max. 31,5 dB(A) | max. 38,4 dB(A) |
MTBF | 30,000h | 30,000h |
Speedometer signal | yes | yes |
Auto-Restart | yes | yes |
Technical data aRGB illumination | ||
LED type | 5V aRGB | 5V aRGB |
Connection | 3-Pin JST | 3-Pin JST |
Max. current consumption LEDs | 3,5W | 3,5W |
LED quantity | Frame: 12 / Hub: 8 | Frame: 16 / Hub: 8 |
shop offer >>> Alphacool Rise Aurora 120/140mm fans in white!
