messi6502
Hello,
I'v checked the waterblock finder, the manual of 18670 and also AMD compatibility list (there is no 6750XT listed in that spreadsheet) and I didn't see the sapphire nitro+ edition to be compatible with 18670 eisblock but based on the picture about the reference PCB in eisblock manual and based on this teardown video it seems the same PCB for me.
Only difference is there is an additional hole in reference where the ARGB pin on nitro+ but in the manual of 18670 I didn't see it is used for mounting the block or the backplate.
Can you please check if its compatible or may I missed something?
