Jessica-Tech
I hope it is okay to post this here, else just delete it.
I am going with the o11d XL and this distro plate https://www.ekwb.com/shop/ek-classic-dp-side-pc-o11d-g1-d-rgb-ddc-3-2-pwm
My question is: Can I make one or both of these fit the drain port on the back? If yes, then what would I need to make it fit? I want to connect a soft tube to the drain port of the distro, and the other end of the soft tube to the ball valve. So it is like this: Distro plate<--->Soft Tube <---> Ball valve <---> soft tube. What do I need to make that setup?
1: https://www.alphacool.com/shop/fitt...hacool-eiszapfen-2-way-ball-valve-g1/4-chrome
2: https://www.alphacool.com/shop/fittings/ball-valves/20219/alphacool-2-way-ball-valve-g1/4-chrome
