So I got the distro plate 240 and it seems this thing is designed completely wrong. So the cool water goes into the gpu1 then the HOT GPU1 water goes next into the CPU and then it goes back to the radiator?
Why on earth would the CPU get the hot water from the GPU.. shouldnt the distro plate take the cold water and split it up and supply cpu and gpu independently with cold water then bring it together to a hot water tank and then send that one out to the radiator.
I am literally dumbfounded why Alphacool would design a distro plate that feeds that hot gpu water into the cpu!! Can anyone explain the rational behind that, when a slight change would provide much cooler water to the cpu??
