Do the two products share compatibility lists with each other?
hyeong
hello.
I am going to buy our water block.
But I can't use high height water block because I'm an sff user.
In the meantime, I came across a water block from your company.
Alphacool ES Geforce RTX 4090 Reference Design mit Backplate
↑ This product.
Unfortunately, inno3d's products cannot be purchased in my country.
Meanwhile, a new water block has been released.
Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Reference mit Backplate
↑ This product.
But the above product has it. The graphics cards that I can buy are listed.
The products I can purchase are from pny or kfa2.
Alphacool Eisblock Aurora Acryl GPX-N RTX 4090 Reference mit Backplate's compatibility list includes inno3d products
So, is the Alphacool ES Geforce RTX 4090 Reference Design mit Backplate compatible with pny or kfa2's products?
And one more question.
I can buy the 4090 Founders Edition.
However, water blocks that are compatible with the Founders Edition will drain upwards.
This is bad for sff cases.
However, the Founders Edition does not share the reference design and pcb layout.
Do you guys have plans to make one?
The Founders Edition water block that drains through the side
Vanzin
HI,
You can check our configurator or PDF list regarding the compatibility. Some PNY and KFA²cards are using the reference layout. But please note that PNY is not compatible with our ES water block for the reference layout.
For the RTX 4090FE is already a water block out for pre-orders.
hyeong
안녕,
호환성에 대한 구성기 또는 PDF 목록을 확인할 수 있습니다. 일부 PNY 및 KFA² 카드는 참조 레이아웃을 사용하고 있습니다. 그러나 PNY는 참조 레이아웃용 ES 워터 블록과 호환되지 않습니다.
RTX 4090FE의 경우 이미 선주문을 위한 워터블럭입니다.
thank you!
