Eisbaer Aurora 240, too large tubes for my case
obahamonden
Hello dears I recently purchased an Eisbaer Aurora 240 and installing it in my NZXT H440i cabinet I see that the tubes are very long and collide with the top fans (the radiator with its fans are installed in the front). Is there a way to change the tubes for shorter ones? can you help me choose?
Also I think that the exit of the tubes from the pump would be more practical if it were not straight if not in L, is it possible to change this too?
Thank you
obahamonden
Thank you
If i understand, actually the original tubes of aurora are about 30cm large, the extension set has 30cm too so this cant solve my problem. The solution was to make a custom tube, using the tube (330cm and cutting) and fittings separately, right?
The TPV series has 12,7/7,6 tube sizes...can i use this fitting?
https://www.alphacool.com/shop/fitt...hread-to-g1/4-inner-thread-deep-black?c=20647
Can i use another tube sizes?
Sorry but i don't understand a lot of this thing. If you can give me some alternatives.
My idea is to use 90º fitting on the pump and black tube (20cm i think is OK). I like the look of the fitting that i show above.
Thank you
