xdk_E53
Hello, I would like to ask if my recently bought Eisbaer Extreme noise is normal.
The built-in pump making loud noise at 100% (4400rpm) and is audible even in lowest possible rpm (c.a 2100rpm). The noise is similar to sough, a bit whistle, maybe jet airplane. No rattle or buzzing.
I switched from Arctic Liquid Freezer II 360 and pump was completely inaudible. Also in the past I used more well known AiOs like Kraken or other Asetek's and never heard something like this from AiO pump.
After Reading all reviews how extremely quiet the Eisbaer Extreme is, I'm a bit disappointed.
Also, in advance, I filled some more ml's of CKC to completely full liquid capacity, I tried to shake the cooler, and Im sure its the Pump Noise, the AiO fans were disconnected, PSU, GPU and other fans are stop.
Also, one more question about pre-built Be Quiet fans, when I tuning machine Off, and fans are about to stop, both of them making annoying, rattle noise. It happening only at this moment, non at start. Is this supposed to be like this? I also never before heard something similar on 120-140mm fans.
Thanks for help.
Thanks for help.
