ChaplainTIG
Workstation with AlphaCool Eisbaer AIO and AMD Ryzen 9 3950X hitting temps between 103-107 when initiating a CPU based Maya Arnold IPR. When I use GPU IPR, temps are fine.
I have a A/C unit that I blow into the case during long renders, with temp sensors for incoming air and outgoing from the loop radiator, and even pre-chilled with the incoming air at 12c and out at 23c, the CPU still immediately hits 100c+ and if I don't stop the IPR immediately, the PC shuts down (so I'm pretty sure it's not a sensor error).
Confirmed that the same is happening when I attempt a batch, with CPU as the render method.
Also load tested with Cinebench, and got into the 80s, but nowhere near the 100+ with Arnold. This workstation normally never gets above 80, so I’m concerned.
In an attempt to figure this out, I've re-applied thermal paste and ensured there are no air bubbles in the loop. I’ve made sure there aren’t any updated to the related programs, BIOS or firmware.
I’m posting this in forums for AMD, Maya, and Arnold.
Not sure what to do next and I’m looking for some external wisdom. Thanks in advance!
Details:
Maya 2024
MSI PRESTIGE X570 CREATION EATX AM4 Motherboard
Processor AMD Ryzen 9 3950X 16-Core Processor 3.98 GHz
Installed RAM 128 GB
Windows 11 Enterprise
Version 22H2
OS build 22621.1702
Experience Windows Feature Experience Pack 1000.22641.1000.0
Details:
Maya 2024
Version 22H2
OS build 22621.1702
