Delarok
Hey, I am using the eisbear and the eiswolf 2 in a loop together for some time now. The only thing that bothers me is that the tubing is way too long for my case. I would like to change the tubing and refill the loop. Is this possible for both products and can I somehow reuse the fittings? Maybe there is a guide out there that I can follow? Also which liquid should I use to fill the loop and do I need to keep the gpu and cpu pump connected when refilling or is one pump enough?
