Eisbecher D5 pump/reservoir 250mm #15233
Monta16
Hello,
I have bought the 250mm version of this combo, and I would like to know if it could be mounted horizontally or it should be only mounted vertically.
Problem is 250mm is too big for my case....
Thanks.
Horizontally is possible but be sure that the reservoir is completely full with water.
15311 is a 60x105mm tube... only the tube, thats not a reservoir but you can replace your tube from 15233 with this shorter tube.
Monta16
Yes, sorry... I meant changing only the tube with the shorter one...
15311 should be the right one, correct?
Monta16
One more question...this hole in the back of the Alphacool Eisbecher D5 250mm Acertal reservoir, is an IN or OUT ?
Monta16
Thanks Eddy.
I see it...so I would need to change system then....could it be possible (since I already have the reservoir) to buy only the bottom Acetal part that you see in this product ?
Then I would need only an Eisdecke D5 Top and I am set, I believe !
Thanks !
