Eisblock Aurora Acryl RGB plug
Roshol
Hello,
I ordered the Eisblock Aurora Acryl for RTX 3080 FE and I would like to know if I can plug the RGB connector (3-pin jst 5V according to the manual) to this controller :
https://fr.aliexpress.com/item/32971783441.html?spm=a2g0w.12010612.8148356.3.197f55dfI3cOJ9
I don't know if it's physically possible to plug it like the upper figure. What should I buy if it's not possible? my asus motherboard only have 4pin 5v header.
Thank you in advance for your help.
Roshol
Roshol
Seems like Barrow is using own connectors, so please ask Barrow for help.
If your mainboard has a 4-Pin connector than its a 12V RGB header not aRGB. but you can use any aRGB controller with normal 3-Pin 5V connectors. Or you can use our Eis Matrix II or our small simple connector: https://www.alphacool.com/shop/modd...a-eiscontrol-addressable-rgb-controller-black
Thank you for your answer, my motherboard have a 5v 4pins connector as following:
So I suppose the connector you sent me would fit, but do you have just the cable without the controller? Thank you.
edit : sorry for the misunderstanding, the connector of my motherboard is a 3 pin but it take 4 slot.
Luckystricker
Official Alphacool Staff
Hi @Roshol
For that you need this cable.
You just have to be careful that your parts also have the JST connector.
No more than 120 LEDs or 3 A total power may be connected to one connector on the mainboard.
Best Regards
@Roshol
:D That 3-Pin Connector wich uses 4 slots is the typical 3-Pin 5V aRGB Header. I know this can be irritating and many people don't get along with the new connections for argb. But this is exactly the classic aRGB 3-pin 5V connection.
