Hello,
For the Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Reference (13038) what is the Inlet port?
It probably doesn't matter but I would like to be sure.
Thank you for your patience.
It doesn`t matter wich port you are using for IN and Out at the active backplate. You only have to consider the flow direction of a cooler if a jetplate is installed, which is not the case with the backplate. This is a simple flow-through cooler.
