I purchased an Eisblock GPX waterblock for reference AMD RX6700XT gpu and i have a small issue with installation with the backplate.
The 2 rear screws M2x11 do not fit and backplate is not 100% secures and thermal pads has too little pressure.
There is no standoffs in the waterblock itself so no threads are present.(gpu block has threads and nut and screw can be used)
The installation manual has a wrong installation for IO shield because only one screw and nut is required not two and you use the stock screw for the other .
Temps are ok for the block i gpu 45c and die hotspot about 20c lower.
Got about 1.5% better 3dmark timespy result than with standard aircooler.r
Memory temps are about 30c lower than standard air cooler.
And its the block for reference amd card number 11965
Any ideas how to fix the issue?
