Eisblock XPX CPU leaking during leak test
Schnoggi
Hi there, I have a potential n00b issue.
I had to disassemble my Alphacool "Eisblock XPX CPU - deep black" to clean out some gunk that had formed in the loop over 8 months. This being my first time doing so I watched a lot of guides on youtube and then proceeded to clean it. I put it back together and made sure the o-rings were all in place and the flowplate and cooling plate were correctly aligned. Before adding it in to the new loop I did a pressure test with a "Alphacool Leak Testing Tool incl. Pump", setting the pressure to 0.5 bar and in another test at 0.7 bar. In all tests I noticed a slow leak that was not there before cleaning it.
Now I have taken it apart mutliple times trying to troubleshoot th issue, focusing mainly on the o-rings, but to no avail.
I also double checked that the leak tester tool wasn't leaking
Is there an obvious solution I'm not seeing, do I have to change all the o-rings for it to work or did I break it and I need to get a new one? (really dont wanna do that last one)
Any tips would be much appreciated :)
Here is a picture of the block
Schnoggi
Just an update:
I did an extensive leak test with water on both my CPU and GPU blocks (both were leaking air) and had no leaks leaving them on for 2 days. So I guess using air for leak testing is not a 100% accurate ¯\_(ツ)_/¯
Here's what my monstrosity looks like in all its glory:
