Eisblock XPX missing am4 washers
Narioh
Hi! I've recently bought an Eissturm Hurricane Copper. I am missing 4x2mm washers from AMD mounting set for AM4
Can they be replaced with regular (8x M4 1mm) washers from the local store?
Luckystricker
Official Alphacool Staff
Hi @Narioh
Then these washers should be made of plastic, at least the ones in the set are made from them.
The inside diameter is 4mm, the outside diameter is 7mm, the thickness would be 2mm.
Best Regards
