Eiswand + RTX 3080
hi everyone,
my current watercooling setup is as follows:
-Eiswand cooler (https://www.alphacool.com/eiswand) on a 7820x
My desired watercooling setup is:
-aphacool waterblock for the gpu (https://www.alphacool.com/shop/gpu-...-gpx-n-rtx-3090/3080-with-backplate-reference) (to be ordered)
-tubing case passthrough panama https://www.alphacool.com/shop/radi...sories/7438/alphacool-hf-38-slot-cover-panama
Ordering the waterblock is not an issue, understanding which connectors/plugs/fittings I need is driving me nuts. 😅
I actually ordered a few wrong fittings a few weeks ago and i just don't want to do that again.
Question 1:
Can someone please advice me whether this loop is proper?
-Eiswand cool side -> panama thingy fitting -> cpu cold -> cpu hot -> gpu cold -> gpu hot -> panama thingy fitting ->Eiswand hot.
Question 2:
which fittings do I need to finish this loop?
the tubing used is the 8mm/11mm as standard in the eiswand package.
Many thanks in advance and i'm sorry for not connecting the dots myself thus far.
cheers
