Eiswolf 2 AIO 3080 + NexXxos ST30 280mm AIO Edition
wind1e
Is it possible to buy the Eiswolf 2 AIO (for 3080 reference) without the 360mm radiator and fans?
I would like to pair it with a NexXxos ST30 280mm AIO Edition instead because I would prefer to use 140mm fans instead and I would assume a 280mm radiator would have quite similar thermal performance as a 360mm has.
Thomas_S
hi, the AIO is only available like this. But you can put together the rest in the shop. All components of the AIO are part of our DIY range. Only the pump housing for the DC-LT 2 pump is a custom-made product that is only included in the scope of delivery of the AIO solution.
wind1e
Understood, thank you for the response. Picking the components from the DIY range is a less attractive option looking at the total cost and I suppose also convenience. A response in this thread indicates Eiswolf will be offered without the radiator. Can you clarify is this still the plan?
Thomas_S
hi, there is no decision yet on whether we will offer it or not.
