Hi,
I have had the Eiswolf 2 AIO - 360mm RTX 3090/3080 for almost 2 years now and it has worked great until a few months ago where my graphics card will crash games or even cause the computer to reboot. I suspect the card itself is not getting cooled enough anymore. Could the orientation of the radiator be a problem? Should I check to see if the liquid is low?
Any ideas of what I should check next?
Image of the setup below, appreciate any help!
