Eiswolf 2 for Inno3d 3090 iChill X4
Thomas_S
unfortunately, this card has not yet been listed for the new cooler. Only a picture of the PCB will help us to make a decision.
Andi197
Member
Okay, in the compatibility list there is the cooler 11942 and under eiswolf 2 it says: coming soon. Maybe I go for a Full Costum build when the 11942 arrives next month. I wish I had a reference design. these coolers are in stock. Thanks for your help @Thomas_S @Eddy
danfullstop
Ordered mine a little while ago, slightly disappointed it isn’t a full cover block for the 3090 but at the same time do understand that they need the product to cover as many GPU's as possible and I would rather that was the case and it was released than it not being released at all. This block for a 3080 would be really good as all the RAM will be covered, not as good for us 3090 owners as the back is still passive but im obviously not that bothered otherwise I wouldn’t have ordered one, im just hoping it fits in my case as I already have a 360mm in there for the CPU :oops: and I was expecting this to be a 240mm.
Thankfully my shipping wasn’t a lot, although im not sure if ill get hit with import charges to the UK after the lovely brexit happened… we shall see.
Bullant
You have me worried now. The descriptions says that the watercooling is applied to the VRAM, and that is the only reason I am buying, my GPU temps are fine but VRAM is through the roof!
Bullant
Just went and read the product description again:
Fullcover Waterblock?
Sounds like it is a fullcover waterblock and will cool the VRAM, no?
danfullstop
Didnt mean to worry you sorry!
The images and the description show a backplate and the block only covers the GPU side (which also has VRAM on it) but on the 3090 there is also VRAM on the rear.
Bullant
Fingers crossed. Hopefully with a proper backplate and thermal compound that actually bridges the gap between the ram and the backplate (my $3K card has none!) all will be good.
danfullstop
Im hoping the same, my Zotac is useless at cooling unless the fans are really high, which kinda of tells you how useless the cooler is.
