Eiswolf 2 pump help.
issacparker95
New pump, installed, but pump isn’t moving water; pump is showing 2600+ rpm I’ve seen a single bubble wiggle but I’m not sure it’s actually pushing/pulling water. Again this is new. Should I flush the system and refill even though it hasn’t been used but to check bios/ fan curves and get everything functioning smoothly.
Vanzin
Hi,
when the pump shows a RPM in the BIOS, then is the pump running. Since the water flow of the DC-LT is very low, it isn´t really visible that the liquid is moving.
issacparker95
Sorry im jsut now seeing this. It is running and functioning as it should. I do have to run the fans fairly high to keep the temp down. Other than that, a new thing occurred today. I run it with white rgb pulse; i noticed when all the rgb is lit it is now faded to a yellow ish color but singly it is nice and white. I put it on a static setting and the white isnt white but the yellowish. Is my strip for the white setting going bad? Other colors illuminate as they should from what ive gone through.
