DGinUK
hi
hoping someone can help, I upgraded the 5700XT Anniversary edition blower (noisy and didn't cool at all) to an Artic Accelero Xtream IV. This was better as I could run fans at 100% and the card didn't crash. I was getting 71c GPU and 96c junction temp at 100% load. I was getting glitches on screen which was annoying.
I opted for the Eiswolf 240 GPX pro for 5700XT M01 as I wanted core and junction to be lower.....
I fit its yesterday and I get 61c GPU and 106c junction temp at 100% load
surely this is not good? I've moved case around and there is no bubble sound.
current set up is :-
NZXT H510 case
NZXT CAM (fan controller)
msi x470 gaming plus System Board
AMD Ryzen 2600
the pump is fitted to the Pump fan header on system board (set to 100% and showing 2300RPM in bios) and the fans are 1400RPM on the radiator when at 100% GPU load, using the NXZT CAM controller. the fans can go 25% more but with little effect on the temps.
I've tried auto under volt in AMD software, I've tried reducing max GPU MHz by 10% and temps are same.
Rad fans are sucking air from front and the two case fans are sucking air out case. PSU is in bottom of case and sucks air in bottom and blows out the back.
any help would be most welcome
NZXT H510 case
AMD Ryzen 2600
