CycleChris
On my Alpha cool eiswolf 2 I have a vertical mount Gpu. (Reference 6900xt model) One of the hoses is a bit kinked coming of the pump. It currently is a 90degree swivel fitting. A straight fitting would work better. Can I purchase a straight fitting coming off the pump on the gpu? Never done any custom loop, asking if it would be difficult to change. Thanks, by the way it solved my overheating card issue, great product!
