ultim802
Quick question: I was hoping to plug the radiator fans into the GPU fan header, but with the waterblock installed there appears to not be enough room to plug the fans in (see attached image). I assume then the fans must be plugged into a fan header on the motherboard. But then what do I do to control the fans? I believe the motherboards fan controller is all based on CPU temp, not GPU temp. Or do I simply have the fans run at a static RPM all the time?
Thoughts?
Thoughts?
