Alphacool presents the ES U-shape RAM water cooler, an efficient way to successfully cool up to eight high-performance RAM modules in server and workstation systems.
Modern RAM modules are becoming increasingly powerful and therefore generate more and more heat. The new U-shaped water cooler, made entirely of copper, can dissipate this heat very effectively. The reliable cooling of the RAM prevents power losses and thus ensures a stable system. Its flat design and versatile connection options allow for easy installation in almost any server or workstation setup. The inlets and outlets to the front and sides enable a highly flexible integration into the cooling circuit.
The ES U-shape RAM water cooler pump is now available in the Alphacool online store.
Features: Modern RAM modules are becoming increasingly powerful and therefore generate more and more heat. The new U-shaped water cooler, made entirely of copper, can dissipate this heat very effectively. The reliable cooling of the RAM prevents power losses and thus ensures a stable system. Its flat design and versatile connection options allow for easy installation in almost any server or workstation setup. The inlets and outlets to the front and sides enable a highly flexible integration into the cooling circuit.
- Dimensions (L x W x H): 185,26 x 62,46 x 21,50mm
- Material: Copper
- Weight: 240g (water cooler solo), 530g (with RAM cooling plates)
- Covered RAM-Slots: up to 8
- Gap between cooling channels: 5,47mm
- Pressure tested: 0,8 bar
- Threads: 2x G1/4“ In | 2x G1/4“ Out
