Brilliant in white? Alphacool expands the high-end version of the valued connector series with the new Eiszapfen in white.
The proven Eiszapfen connectors from the Alphacool convince with high flow, attractive design and solid workmanship. Due to the uncompromising design and manufacturing, a secure and firm hold of the hoses is provided. To achieve high durability and the intense colors, the surface is coated using a special process that prevents the paint from chipping off. The distinctiveness of Alphacool connectors is emphasized by the logo on each connector.
The white Alphacool Eiszapfen 13/10mm compression fitting G1/4 as well as Alphacool Eiszapfen 16/10mm compression fitting G1/4 are offered as Single and Sixpack and are, like Alphacool Eiszapfen angled adaptor double-45° rotatable G1/4 outer thread to G1/4 inner thread, Alphacool Eiszapfen 2-way ball valve G1/4 and Alphacool HF connection terminal TEE T-piece now available in our online store.
