Kyuss
![1 Reaction score](/styles/XENTR/ReputationSystem/empty-star.png)
HI, I have an Eiswolf for a rtx4090 and an Eisbaer Pro HPE for a 13900k and I'm thinking in using the components to make a semi-custom circuit. But I'm stuck choosing the fittings for this particular tube size (12,7-7,6mm). I need some 90, 45, straight and Quick Disconnect fittings. Looking in the site the only ones are the compression fittings that came with the AIO's and the Nylon QDC's (HF and ES).
What exact measure I must use for replacing the fittings with a new ones or should I change the tubing size?
Thanks.
Thanks.
