Fluid direction plug help
fenice19
hi. I ve modded my eisblock xpx disconnecting tubes from eisbarer extreme black. Non i ve a doubt a out reconnectio, i've forgotten how it was connected before.
I think (" OUT marked" hole of radiator to "IN marked" hole of eisblock and IN of radiator to OUT of eisblock.. is it true?
Luckystricker
Official Alphacool Staff
Hi @fenice19
If i understand you correctly, you mean how and where which hose has to go, right?
So from the Radiator Out to the left connection of the XPX, and from the right connection of the XPX to the IN of the radiator.
it can also be read inside the XPX
I hope i can help, my english is not the best.
