luisechenique114
Hello, I live in Peru (south america), recently I received a GPU waterblock for my 3080 aorus master from Performance PCs.com, however, while installing it to my current loop, I noticed the coolant could not flow through it, after several hours of troubleshooting, I removed the GPU block and tested it with a compressed air leak tester from EKWB, just to see how water would behave, but air won't pass through either, even with outlet ports open. I wondered what can I do to fix this? Is my unit a bad one? I would really appreciate your help.
Loop is working just fine without the GPU block, I even tested the GPU block with a rad only without positive results.
As you can see in the image, outlet ports are fully opened, however, the leak tester is not losing pressure, air won't flow.
