Help choices with case HAVN HS 420
si_92
Hi,
I'm asking for support here in the forum because I have a HAVN HS 420 case.
I want to improve cooling performance by adding another radiator to my PC, a 420mm Alphacool radiator with 140mm fans and a height of 25mm at the bottom, and adding an Alphacool distro plate to the right side of the case because I like its aesthetic. (I already have a 360mm top-side radiator)
Unfortunately, I can't find much information or photos online (how strange)
My questions are:
- Would it be better to buy an Alphacool NexXxoS UT60 Full Copper 420mm radiator or the Alphacool NexXxoS Monsta 420mm?
- Is the Alphacool Core 420 Left VPP/D5 distro plate compatible with the HAVN HS 420 case or could there be issues with the bottom fans/radiator? (like space problems between the radiator I want to add and the distro) [added some pics about it]
Thanks in advance,
SI
