DarkGabriel1991
Hello!
First of all, sorry if you find some bad English typos.
I'm so excited to build my first custom water cooling loop, the last pieces are arriving (all from Alphacool), but I'm a little afraid with this situation.
I want to set the in of my reservoir from the top, so I was thinking, as I see in the fitting interactive map, to use a Y-shape fit with the incoming tube in the inclined angle (45°), and fill the reservoir from the right angle. But maybe one fill of coolant will not be enough, so I don't know if, after the first loop filling by activating the MOBO, and after power off, I can securely open the screw plug I will place at the top of the Y-shape fit, refill the missing coolant in the reservoir, and restart the MOBO to check if more coolant is needed.
Maybe the physics law I don't study at the school or some fluid and pipes principles unknown by me can play a crucial role in this plan but I prefer to get help from some experimented user to help me to understand if I make a mistake in my combination, miss to buy some other components to a more safely fill, or (the positive side) everything it's gonna be alright.
I want to get my PC water cooled because the summer is really hot here at Italy, I cannot put an air conditioner at my house (at the moment) and I want to navigate with Jack Sparrow at the Sea of Thieves new event, but this game makes my PC run so holy guacamole ? HOT AS HELL ?
Better if I take the safe way to play You will find some images as reference, make me know if want to show you all the buy list or the specs of my PC build.
Cheers!
Image #1: some of the items I bought
Image #2: the part of the interactive map I use to set the idea
Cheers!
