Hello
I would like to extend my Eisbaer Pro Aurora 420 with a second CPU AIO (I have a dual-system case).
I only have room in the case for a 1x140mm radiator on the rear exhaust fan, and the CPU is low power so I am not worried about the cooling capacity.
But there is no off-the-shelf 140mm CPU AIO with quick-connect. So I figured I could put together one from parts.
What I have so far is:
Do I need other accessories ?
Having 2 TPV extension cables will be too much length for my setup, is there a way to use a single TPV extension kit somehow ?
The resulting loop will be cooling 2 systems (2 CPUs, in a dual-system case), but it could be that only one of them is powered on. Is it ok for the two pumps in the loop, if one pump is powered on, and the other pump is powered off ? Can this work ?
- Eisbaer Pro Aurora (solo) digital RGB
- NexXxos UT60 Full Copper 140mm
- Eisbaer TPV extension set 90°
- Eisbaer TPV extension kit
