Product: Alphacool Eiswolf 2 AIO - 360mm RTX 3090/3080
Article number: 11931
GPU: Inno3D GeForce RTX 3080 Twin X2 OC, 10240 MB GDDR6X
I ran into the same problem as many others: VRAM breaching 100°C at 100% TDP.
Turns out that my card needs 1.2-1.3mm thermal pads with the Eiswolf Zwei.
(It used 0.8mm with the awful stock cooler)
Vram temps are 30°C lower now.
Ambient temperature: 25°C
320W @ MSI Kombustor FurMark-Donut-6500MB, 15 minutes
Alphacool fans @ 1500 rpm (loud, but bearable)
Gelid GP-Ultimate 1mm thermal pads:
Core: 65°C
Vram: 106°C
HotSpot: 74°C
Gelid GP-Ultimate 1.5mm thermal pads flattened to ~1.2mm:
Core: 66°C
Vram: 76°C
HotSpot: 77°C
80W (5k×1440@240Hz HDR) @ desktop idle
Alphacool fans @ 700 rpm (silent)
Core: 36°C
Vram: 64°C
HotSpot: 54°C
Gelid GP-Ultimate ~1.2mm thermal pads:
Core: 36°C
Vram: 48°C
HotSpot: 54°C
Story time
First I was using Gelid GP-Ultimate 1mm thermal pads:
![1.jpg 1.jpg](https://forum.alphacool.com/data/attachments/5/5175-8b11e8bb7b73c2dfc3c2e9789c40c1bd.jpg)
Then I tried 1.5mm:![2.jpg 2.jpg](https://forum.alphacool.com/data/attachments/5/5176-b77414a7082d40c60023dd1827d184fc.jpg)
Too thick:
![3.jpg 3.jpg](https://forum.alphacool.com/data/attachments/5/5177-bb7781d8767e0df49c4a260e529855b9.jpg)
So I flattened the 1.5mm's a bit by rolling a small bottle over them
Edit: don't bother doing this, just e-mail Alphacool support (info@alphacool.com) for thermal pads with appropriate thickness.
![4.jpg 4.jpg](https://forum.alphacool.com/data/attachments/5/5178-23382b672b5ce636bda7ecbe9257a826.jpg)
I could have discarded the excess thermal pad surface, but I've already spent countless hours installing this cooler:
![5.jpg 5.jpg](https://forum.alphacool.com/data/attachments/5/5179-7cca4d87e44c82989e96953f0dca65f6.jpg)
To my surprise, it finally fit well enough. Hotspot is a bit higher, but temps are excellent all-around.
![6.jpg 6.jpg](https://forum.alphacool.com/data/attachments/5/5180-78941abb5e205d6e7a8a2d9323e444a4.jpg)
Core: 65°C
Vram: 106°C
HotSpot: 74°C
Core: 66°C
Vram: 76°C
HotSpot: 77°C
Core: 36°C
Vram: 64°C
HotSpot: 54°C
Core: 36°C
Vram: 48°C
HotSpot: 54°C
Story time
Then I tried 1.5mm:
Too thick:
