Inno3d RTX 4090 ichill frostbite ; Rx7900 xtx
Ghostrider.1127
First post first question....
Got a Inno3d RTX 4090 ichill frostbite , as it ´s using an Alphacool block , the question is : can i buy the spare pads ( code13442) or i´m missing something?
Also need a set of Thermal pads for my Shappire Rx7900 xtx ( also under Alphacool block) where i can order them?
Thanks in advantage
astaaa
Administrator
Hi, with the follwoing link you can buy the thermal pads for the 4090.
Here you can find the thermal pads for the 7900
For the Backplate you need 3W/mK and for the cooler 7W/mK thermal pads.
Ghostrider.1127
This two than ?
astaaa
Administrator
The dimensions for the pads in terms of length and thickness can be found in the instructions. You will find all the information there.
