Leak
Salazaar
I bought a NexXxoS X45 120mm V.2 and an Eisbaer Extension set from Aquatuning but when I connect them they leak from both joints - I've tried contacting Aquatuning but not got a response yet. Is there anything else I can do?
Unfortunately, it leaves me with a bit of a problem as I also bought an Eisblock Aurora GPX-A, which the extension kit (I bought two kits) does fit, but I can't add it to my loop without the additional radiator.
Metropolis34
You can not screw the connections right? The V2 radiators the new ones the screw thread hole is only 5 mm deep. Probably your extension kits are 7 mm. That is why you can not screw them on the radiator. Please write an email to info@alphacool.com We will send you some extension kits with the correct size.
