MCX 5x divider
On the 2nd block (the first I ordered a long time ago and hasn't leaked) 2 of the 5 3mm pressfit fittings seem to be leaking. Is there a fix for it?
(without RMA/international shipping etc... )
I'm tempted to dump some epoxy in it block all the ports and pressurize it but have mixed results in the past.
This is the only issue I've had with Alphacool parts. If this was "pushed out the door" I would appreciate a "I'm willing to wait" option on order(I'm saying because the 'lead time' was significantly longer than the time I received parts).
Thanks,
Ethan...
I can't recommend a DIY solution here. If it doesn't work, we'll be the bad guys again. Therefore, I can only advise you to get an RMA. Write directly to our support: info@alphacool.com
Epoxy resin is not a real solution. In continuous operation, substances dissolve and end up in the circuit. That is not so ideal. Mostly not bad, but you should avoid it.
