Mounting Question for Alphacool Eiswolf 2 AIO - 360mm RTX 3090/3080
danfullstop
Hi,
This is probably covered in the manual but as I yet to receive it I wanted to plan where its going in my case. Are there any limitations of the orientation of the rad? To allow this to fit in my case I need to mount the rad with the pipes at the bottom of the case which would mean the pipes on the pump would also need to point down rather than up as shown in all images of it, I assume this wouldnt be a problem?
Thanks,
Only important thing is, that a part of the radiator must be on a higher position than the Pump on the GPU.
Any part of the rad. And to be honest, its better if IN and OUT are on the bottom and not on the top ;-)
danfullstop
Thats good as it wouldnt fit otherwise :) perfect, thank you, looking forward to receiving it and hope I dont get hit with import charges to the uk!
