Need help with my first loop. Which set if any?
dmill
Hello,
I'm looking to do my first loop and there are too many moving parts to this equation and I could really use some help.
I'm looking to cool the GPU and CPU in this system:
PCPartPicker Part List
CPU: Intel Core i7-14700KF 3.4 GHz 20-Core Processor
Motherboard: Asus TUF GAMING Z790-PRO WIFI ATX LGA1700 Motherboard
Memory: TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory
Storage: TEAMGROUP MP34 4 TB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive
Video Card: Gigabyte GAMING OC GeForce RTX 4090 24 GB Video Card (REV 1.0)
Case: Fractal Design Meshify 2 XL ATX Full Tower Case
Power Supply: Super Flower LEADEX VII XG 1300 W 80+ Gold Certified Fully Modular ATX Power Supply
Monitor: Acer Nitro XV1 XV271U 27.0" 2560 x 1440 180 Hz Monitor
Are there any sets that could make my life easier? Or a breakdown of parts I should purchase? I initially wanted to get a core 1 but I think it would be easier and cheaper to just get a set? Soft tubing preferred.
Any help is appreciated. Thanks!
AndrejsR
GPU https://shop.alphacool.com/en/shop/...re-geforce-rtx-4090-master-v.2-with-backplate
CPU https://shop.alphacool.com/en/shop/cpu-water-cooling/intel/13446-alphacool-core-1-aurora-black
There are other choices but those are the ones I'd buy. It's their newest series.
Do you need some help figuring out what radiators, pump, reservoir, etc?
I'd go with at least a 360 mm radiator. Probably 480 would be better.
Fractal Meshify allows to put 2x 360 and it will give headroom, i would go with max rad space available for 4090 + 15th intel
