NEW – Core Flat Reservoirs 240 and 360
Marc-eting
Marc the Marc-eting Guy
Just stylish - your heart will skip a beat! Alphacool presents the new Core Flat Reservoir. This one is a must-have for any performance-oriented custom water cooling system in which CPU and graphics card(s) are to be cooled simultaneously. The reservoir is available in two sizes, each with and without a pump.
The chrome-plated brass G1/4" connections are a sleek and elegant element of the Core Flat reservoir. The connections, which are embedded in the acrylic and fitted with an O-ring, are absolutely leak-proof and underline the clear and functional look of the Alphacool Core Design series. By not screwing the connections directly into the acrylic, cracking is prevented. Alphacool's Core Flat Reservoir is made of high-quality acrylic, which allows a clear view of the coolant and enables brilliant illumination with the built-in, digitally addressable aRGB lighting.
With the included Core Push Mounting Kit, the reservoir can be easily mounted on a radiator or on the case panel. This ensures stable and secure mounting as well as easy removal for maintenance or expansion projects. The Core Flat Reservoir is now available as a 240mm or 360mm version with or without pump in the Alphacool online store.
Features:
Core Flat Reservoir 240 Right with VPP pump:
- Dimensions: (L x W x H) 240 x 125 x 45mm
- Volume: 270ml
- Connections: 5x G1/4" female thread / 1x fill port
- Number of digital aRGB LEDs: 12
Core Flat Reservoir 360 Right with VPP pump:
- Dimensions: (L x W x H) 360 x 125 x 45mm
- Volume: 500ml
- Number of digital aRGB LEDs: 17
Core Flat Reservoir 240 Right without VPP pump:
- Volume: 270ml
Core Flat Reservoir 360 Right without VPP pump:
- Volume: 500ml
Features of the pump:
- Pump housing material: Aluminum
- Other materials: Plastic & ceramic
- Control range: 2500-4500 RPM via 4-pin PWM
- Maximum delivery head: 4.25m
- Maximum flow rate: 340L/h
- Operating voltage 8-13V DC (SATA Power Management)
