New AiO for CPU Watercooling
Thomas_S
Lots of performance at a fair price. With the Core Ocean AiO, Alphacool presents an all-in-one solution that offers an entry into performance-oriented CPU water cooling thanks to its excellent price-performance ratio.
The difference to Alphacool's Eisbaer CPU AiO is that the Ocean All-in One is not expandable. Adding more components such as radiators, pump or expansion tank is not intended here. But also not necessary! The choice of components and the design of the Core Ocean AiO allow a long lifetime with low maintenance for water cooling of all common mainstream sockets from AMD and Intel. The included mounting hardware already allows Alphacool's latest all-in-one to be used on AMD's AM5 socket.
Features
Radiator
- Material: 3003 aluminium
- available sizes: 120mm, 240mm, 280mm, 360mm, 420mm
Fans
- Alphacool Core 120mm & 140mm
- Connection & control: 4-pin PWM
- Fan speed Core 120mm: 0-2500rpm/min (±10%)
- Max. Air Flow Core 120mm: 62.8CFM
- Max. static pressure Core 120mm: 2.13mm/H2O
- Fan speed Core 140mm: 0-2000rpm/min (±10%)
- Max. Air Flow Core 140mm: 92.3CFM
- Max. static pressure Core 140mm: 2.53mm/H2O
Cooler & Pump
- Material cooler bottom: copper
- Material pump housing: synthetic material (ABS+PC)
- Fin structure cooler bottom: 0.1 x 0.1mm
- Pump bearing & shaft material: Ceramic
- Number of aRGB LEDs: 12
- Speed: max. 3500rpm (±10%)
- Intel: LGA 115x / LGA 1200 / LGA 1700 / LGA 2066
- AMD: AM4 / AM5
