We are expanding the color palette! With the Core 1 Aurora White, Alphacool now presents the very powerful CPU cooler in a plain white color. With the help of the completely newly developed 3D jetplate, the enormous waste heat of the latest desktop CPU generation is reliably dissipated.
With the Core 1 CPU cooler, Alphacool combines the best of old and new. In conjunction with the proven cross-slot technology, the new 3D jetplate ensures exceptionally even distribution of the coolant on the redesigned cooler base. Compared to the previous model, a 10 Kelvin lower temperature can be achieved. Milled from a high-quality brass block, the Core 1 has nickel-plated connections. The enlarged cooler base, which is also nickel-plated, allows even very large CPUs to be completely covered.
The elegant and functional design is a central element of the Core series from Alphacool. The visual highlight is the nickel-plated connections, which stand out from the high-quality brass housing. The discreet contour line and rounded corners add the perfect touch to the overall look.
Compared to previous Alphacool models, the modified mounting system requires fewer screws and is easier to handle.
The Core 1 Aurora White is now available in the Alphacool online store.
Features:With the Core 1 CPU cooler, Alphacool combines the best of old and new. In conjunction with the proven cross-slot technology, the new 3D jetplate ensures exceptionally even distribution of the coolant on the redesigned cooler base. Compared to the previous model, a 10 Kelvin lower temperature can be achieved. Milled from a high-quality brass block, the Core 1 has nickel-plated connections. The enlarged cooler base, which is also nickel-plated, allows even very large CPUs to be completely covered.
- Dimensions (L x W x H): 72 x 72 x 26.50mm
- Material: Housing: brass; radiator: nickel-plated copper
- Connections: 2 x G1/4"
- Fin thickness/spacing: 0.4/0.4mm
- Maximum operating temperature: 60°C
- Intel: LGA 1700
- AMD: AM4, AM5
