Even more performance now also for RX 7900XTX Merc 310 GPU! Alphacool expands the assortment with the new and innovative Eisblock Aurora cooler for active water cooling of AMD RX 7900XTX Merc 310 graphics cards.
The enormous waste heat of the new graphics card generation is excellently dissipated with the cooler. Thanks to the particularly filigree fin structure, the cooling surface was increased and a very good water flow was made possible. The jet plate with revised inflow engine also distributes the water perfectly on the cooling fins. The full chrome plating of the copper base not only provides resistant protection against acids, scratches and damage, but also achieves remarkable homogeneity and significant gloss.
In addition to the technical improvements, the Eisblock has received a facelift: The Aurora design is now visually calm and simple, with only one O-ring running around the entire cooler. In addition, the design around the cooling fins and jetplate provides a clean look. The illumination by means of digitally addressable RGB LEDs spreads decidedly evenly throughout the cooler as a result of the chrome plating.
The Eisblock Aurora water cooler for AMD RX 7900XTX Merc 310 is now available for pre-order in the Alphacool Online Shop.
Features The enormous waste heat of the new graphics card generation is excellently dissipated with the cooler. Thanks to the particularly filigree fin structure, the cooling surface was increased and a very good water flow was made possible. The jet plate with revised inflow engine also distributes the water perfectly on the cooling fins. The full chrome plating of the copper base not only provides resistant protection against acids, scratches and damage, but also achieves remarkable homogeneity and significant gloss.
- Chrome-plated copper base
- Enlarged cooling surface due to adapted fin structure
- Optimal distribution of water in the cooler by modified Jetplate
- Brilliant aRGB LED illumination
Compatibility
- XFX Speedster MERC 310 Radeon RX 7900 XTX Black Edition
- XFX Speedster MERC 310 Radeon RX 7900 XT Black Edition
