• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
New CPU AiO from Alphacool! Eisbaer Aurora LT now with aRGB lighting!
Thomas_S
Administrator
With the Eisbaer LT240 & LT360 Aurora, Alphacool today presents new CPU "All-in-One" solutions based on the previously so successful Eisbaer LT series.
Compared to the classic Alphacool Eisbaer LT AIO, the cooler and pump unit as well as the fans of the new Aurora version are now fully equipped with digital RGB LEDs. With the included controller, extensive lighting effects can be set, which provide unique and noble illumination. As with all Eisbaer AIOs, Alphacool again uses the NexXxoS radiator with cooling fins, pre-chambers and cooling channels made of copper as well as the robust TPV hoses with quick-release couplings from the ENTERPRISE Solutions series. With the help of the quick couplings, it is possible to integrate other common water cooling products such as GPU coolers into the loop. The flat pump housing allows the AIO to be installed even in the smallest spaces. Alphacool's Eiszyklon Aurora LUX PRO is used as the fan, the DC-LT pump is replaced by Alphacool's quieter and more powerful DC-LT2 pump.
Thanks to an included adapter, Alphacool's Eisbaer Aurora LT CPU AIO is already compatible with Intel's LGA 1700 socket.
Alphacool Eisbaer LT240 & LT360 Aurora CPU AIO Digital RGB
Technical data radiator
L x W x HLT240mm - 274 x 120 x 25 mm
LT360mm - 390 x 120 x 25 mm
Material cooling fins, chambers & cooling channelsCopper
Material threadsBrass
G 1/4“ threads2 x for tubes
For fan size120 mm
Possible fan assemblyLT240mm - 2 x one-sided / 4 x both-sided
LT360mm - 3 x one-sided / 6 x both-sided
Technical data cooler & pump
L x W x H69 x 69 x 45 mm
Material cooler bottomNickel plated copper
Material cooler topPMMA
Threads2 x G1/4“ (+ 1x Fillport G1/4“)
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
Technical data fan
Speed800 - 2000 RPM
Static pressure2,0 mm H2O
Air flow rate104,49 m³/h
BearingsHydraulic
Fan connector4-Pin PWM
Dimensions120 x 120 x 25 mm
Compatibility list:
- Intel: 775 / 1056 / 1155 / 1150 / 1151 / 1200 / 1700 / 2011 / 2011-3 / 2066
- AMD: AM2 / AM2+ / AM3 / AM3+ / FM1 / FM2 / FM2+ / AM4 / TR4 / sTRX4 / sWRX / SP3
