Alphacool International GmbH from Braunschweig is a pioneer in PC liquid cooling technology. With one of the industry’s most comprehensive product portfolios and over 20 years of experience, Alphacool is expanding its lineup with the Core DDCzero PWM pump, matching Flat Reservoirs, and the Core Universal Mounting Kit.
The Alphacool Core DDCzero combines strong delivery performance with a compact design. Developed for PC water-cooling systems, datacenter systems, and industrial applications, it ensures dependable coolant flow with low power consumption. Power supply, PWM control, and speed monitoring are conveniently handled through a 4-pin fan connector.
The Core DDCzero Flat Reservoirs are available in 90, 140, and 200 variants. Their flat design is ideal for small-form-factor systems and different case layouts. The 200 variant offers the highest filling volume and supports up to two DDCzero pumps.
The reservoirs feature a durable acetal base, a transparent acrylic top, five integrated G1/4" ports, and digitally addressable aRGB lighting.
The Core Universal Mounting Kit enables flexible installation on radiators or 120 mm fan mounting positions. Depending on the available space and tubing layout, the components can be mounted straight or rotated by 90°.
The Core DDCzero PWM pump, matching Flat Reservoirs, and the Core Universal Mounting Kit are now available for pre-order in the Alphacool online shop.
- Compact, low-profile design – ideal for small form factor systems
- Powerful pump with a high flow rate
- Brilliant digital aRGB lighting on the reservoirs
- Flexible mounting of reservoirs and pump tops with the Universal Mounting Kit
{strip} {* Name der Kategorie *} {$sCategory.description|escapeHtml} {/strip}
{strip} {if $seoAttributes.facebook_description} {* Facebook-Beschreibung der Kategorie, falls vorhanden *} {$seoAttributes.facebook_description|strip_tags|truncate:240|escapeHtml} {elseif $sCategory.metadescription} {* Ansonsten: Meta Description der Kategorie, falls vorhanden *}...
shop.alphacool.com
