More performance also for RX 7800 XT GPUs! With the Eisblock Aurora cooler, Alphacool presents an innovative solution for active water cooling of Radeon RX 7800 XT graphics cards with reference design.
In close cooperation with AMD board partners, numerous optimizations have been made to the water cooler in order to dissipate the enormous waste heat of this graphics card generation in the most effective way. The adapted fin structure enables optimum water flow while increasing the cooling surface at the same time. The modified jet plate with improved inflow engine ensures the best possible distribution of water on the cooling fins. The fully chrome-plated copper base is resistant to acids, scratches and damage. In addition, the chrome plating provides evenness and shine that cannot be achieved by nickel plating.
The Eisblock cooler has not only been technically improved: the Aurora design of the Radeon RX 7XXX Eisblock generation is visually calm and simple, as only one O-ring surrounds the entire cooler. In addition, the design around the cooling fins and the jetplate ensures a clearer look. Thanks to the chrome plating, the illumination of the digitally addressable RGB LEDs unleashes an impressive flood of light in the cooler.
The Eisblock Aurora water cooler for Radeon RX 7800 XT Reference Design is available for pre-order in the Alphacool online store.
Features:In close cooperation with AMD board partners, numerous optimizations have been made to the water cooler in order to dissipate the enormous waste heat of this graphics card generation in the most effective way. The adapted fin structure enables optimum water flow while increasing the cooling surface at the same time. The modified jet plate with improved inflow engine ensures the best possible distribution of water on the cooling fins. The fully chrome-plated copper base is resistant to acids, scratches and damage. In addition, the chrome plating provides evenness and shine that cannot be achieved by nickel plating.
- Optimized fin structure enables very good water flow & an enlargement of the cooling surface
- Modified jet plate ensures optimum distribution of the water on the cooling fins
- Chrome-plated copper cooler
- Visually calm & simple design with digital aRGB lighting
AMD Radeon RX 7800 XT, 16GB GDDR6, HDMI, 3x DP
