New Eisblock for RTX 4070Ti and RX 7900XTX
Marc-eting
Marc the Marc-eting Guy
More performance for RTX 4070Ti and RX 7900XTX GPUs! Alphacool expands its range of active water cooling solutions for Nvidia RTX 4070Ti and AMD RX 7900XTX graphics cards with the new and innovative Eisblock Aurora cooler.
Thanks to the particularly filigree fin structure, the cooling surface has been enlarged and a very good water flow is made possible. The nozzle plate with revised inflow also distributes the water perfectly onto the cooling fins. This effectively dissipates the enormous heat generated by the new graphics card generation with the cooler. The full-surface chrome plating of the copper base not only provides lasting protection against acids, scratches, and damage, but also achieves a beautiful homogeneity and a special shine.
In addition to the technical improvements, the Eisblock has received a facelift: The Aurora design is visually calm and simple, as only one O-ring runs around the entire cooler. Furthermore, the construction (design) of the cooling fins and the jet plate ensures a clear appearance. The lighting with digitally addressable RGB LEDs spreads evenly throughout the cooler thanks to the chrome plating.
The Eisblock Aurora water coolers for Nvidia RTX 4070Ti Ventus, Nvidia RTX 4070Ti TUF Gaming, and Nvidia RTX 4070Ti Eagle OC as well as AMD RX 7900XTX Red Devil are now available for pre-order in the Alphacool online shop.
Features
- Modified jet plate ensures optimal distribution of the water on the cooling fins
- Optimised fin structure enables very good water flow & increase of cooling surface
- Chrome-plated copper cooler
- Visually calm & simple design with digital aRGB illumination
Compatibility Eisblock Aurora Geforce RTX 4070Ti Eagle OC:
- GIGABYTE GeForce RTX 4070 Ti Eagle 12G
- GIGABYTE GeForce RTX 4070 Ti Eagle OC 12G
- GIGABYTE GeForce RTX 4070 Ti Gaming OC 12G
Compatibility Eisblock Aurora Geforce RTX 4070Ti TUF Gaming:
- ASUS TUF Gaming GeForce RTX 4070 Ti
- ASUS TUF Gaming GeForce RTX 4070 Ti OC
Compatibility Eisblock Aurora RTX 4070Ti Ventus:
- MSI GeForce RTX 4070 Ti Ventus 3X 12G
- MSI GeForce RTX 4070 Ti Ventus 3X 12G OC
Compatibility Eisblock Aurora RX 7900XTX Red Devil:
- PowerColor Radeon RX 7900 XTX Red Devil
- PowerColor Radeon RX 7900 XTX Red Devil Limited Edition
