New Eiswolf 2 AiO - now also for custom designs of the RX 7900XT/XTX GPUs! Alphacool expands its product range and enables the cooling of AMD's RX 7900XT/XTX graphics cards with the innovative Fullcover GPU AIO water cooler.
The enormous waste heat from the new generation of graphics cards is dissipated excellently with these coolers. The very good water flow and the large cooling surface are the result of the particularly filigree fin structure. The jet plate with revised inflow engine also distributes the water perfectly over the cooling fins. The full-surface chrome plating of the cooler not only offers resistant protection against acids, scratches and damage, but also achieves a beautiful homogeneity and exceptional shine. The Aurora design of the cooler impresses with its visually calm and simple design as well as the wonderfully uniform lighting, which is achieved via digitally addressable RGB LEDs.
The expandable Eiswolf 2 delivers an all-round carefree package and ensures that its user can easily access a performance-oriented GPU water cooling system out-of-the-box. Also included are the NexXxos ST30 360mm radiator, the Rise Aurora 120mm fans, DC-LT 2 pump and TPV hoses with quick-release coupling.
The Eiswolf 2 AiO - 360mm for RX 7900XT Reference and RX 7900XTX Merc 310 are now available in the Alphacool online store.
Features Eiswolf 2 AiOThe enormous waste heat from the new generation of graphics cards is dissipated excellently with these coolers. The very good water flow and the large cooling surface are the result of the particularly filigree fin structure. The jet plate with revised inflow engine also distributes the water perfectly over the cooling fins. The full-surface chrome plating of the cooler not only offers resistant protection against acids, scratches and damage, but also achieves a beautiful homogeneity and exceptional shine. The Aurora design of the cooler impresses with its visually calm and simple design as well as the wonderfully uniform lighting, which is achieved via digitally addressable RGB LEDs.
Radiator
- Material cooling fins, pre-chambers & cooling channels: Copper
- 360mm for 3x 120mm fans
Fan
- Alphacool Rise Aurora 120mm
- Connection & control: 4-pin PWM
- Fan speed: 0-2500 RPM/min
- Max. Air Flow: 119.8 m³/h
- Max. static pressure: 3.17 mm/H2O
Cooler & pump
- Cooler base material: Chrome-plated copper
- Cooler top material: Acrylic
- Pump housing material: Acetal
- Fin structure: 0.4 x 0.4mm
- Pump type: DC-LT 2 (2600 rpm/min +/- 10%)
Compatibility
Eiswolf 2 AIO - 360mm RX 7900XT Reference
- AMD Radeon RX 7900 XT, 20GB GDDR6
- ASRock Radeon RX 7900 XT, 20GB GDDR6
- Asus Radeon RX 7900 XT, RX7900XT-20G, 20GB GDDR6
- Biostar Radeon RX 7900 XT, 20GB GDDR6
- Gigabyte Radeon RX 7900 XT 20G, 20GB GDDR6
- PowerColor Radeon RX 7900 XT, 20GB GDDR6
- Sapphire Radeon RX 7900 XT, 20GB GDDR6
- XFX Radeon RX 7900 XT, 20GB GDDR6
Eiswolf 2 AIO - 360mm RX 7900XTX Merc 310
- XFX Speedster MERC 310 Radeon RX 7900 XT Black Edition, 20GB GDDR6
- XFX Speedster MERC 310 Radeon RX 7900 XT, 20GB GDDR6
- XFX Speedster MERC 310 Radeon RX 7900 XTX Black Edition, 24GB GDDR6
