• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
New Eiswolf 2 for 3080/3090 Aorus Master/Xtreme & 6800XT/6900XT Nitro+ GPU
Thomas_S
Administrator
Alphacool today presents the Eiswolf 2 "All-in-One" solution for Geforce RTX 3080/3090 Gigabyte Aorus Master/Xtreme and Radeon RX 6800XT/6900XT Sapphire Nitro+graphics cards.
The Eiswolf 2 uses the Alphacool 360mm NexXxoS ST30 full copper radiator. For the fans, we use the 120mm Alphacool Aurora Rise. This impressive fan with a max. static pressure of 3.17mm/H2O, offers a max. air flow of 119.8m³/h. The speed range of the fan, from 0-2500rpm, is adjustable via PWM. The AIO is completed by the Eisblock Aurora water cooler. This not only cools the GPU chip, but actively cools all relevant components such as the memory and VRAM. It also has brilliant aRGB lighting.
All components used (radiator, fan, cooler, DC-LT 2 pump) including fittings and tubing are part of the Alphacool DIY range and are therefore available separately. The combination of all components results in a solution that is as easy to install as an AIO, but offers the performance of a pre-assembled and pre-filled custom loop. Only the pump housing for the DC-LT 2 pump is a custom-made item that is only part of the scope of delivery of the AIO solution and is therefore not available separately.​
Alphacool Eiswolf 2 AIO 360mm - Technical data
cooler and pump
Material cooler bottomNickel plated copper
Material cooler topPMMA
Pump typeDC-LT 2
Pump speed2600 rpm (+/- 10%)
radiator
L x W x H395 x 124 x 30mm (+/- 3%)
Material cooling fins, prechambers & channelscopper
Material threadsbrass
For fan size120 mm
fans
Speed0 - 2500 RPM
Static pressure3,17 mm H2O
Air flow rate119,8 m³/h
1. Alphacool Eiswolf 2 AIO 360mm RTX 3080/3090 Aorus Master/Xtreme with Backplate (>>>Shop offer)
Compatibility
- Gigabyte Aorus GeForce RTX 3080 Ti Xtreme 12GB
- Gigabyte Aorus GeForce RTX 3080 Ti Master 12GB
- Gigabyte Aorus GeForce RTX 3080 Master 10G, 10GB GDDR6X, 3x HDMI, 3x DP
- Gigabyte Aorus GeForce RTX 3080 Xtreme 10G, 10GB GDDR6X, 3x HDMI, 3x DP
- Gigabyte Aorus GeForce RTX 3090 Master 24G, 24GB GDDR6X, 3x HDMI, 3x DP
- Gigabyte Aorus GeForce RTX 3090 Xtreme 24G, 24GB GDDR6X, 3x HDMI, 3x DP
2. Alphacool Eiswolf 2 AIO 360mm Radeon RX 6800XT/6900XT Nitro+ with Backplate (>>>Shop offer)
Compatibility
- Sapphire Nitro+ Radeon RX 6800 XT SE, 16GB GDDR6, HDMI, 2x DP, USB-C
- Sapphire Nitro+ Radeon RX 6800 XT, 16GB GDDR6, HDMI, 3x DP
- Sapphire Nitro+ Radeon RX 6900 XT, 16GB GDDR6, HDMI, 3x DP
komar
Hi Alphacool,
any chance we will see a Eiswolf 2 for MSI RTX 3090 Suprim X, those 450 watts need some love
