New in our assortment - Active backplates for Geforce RTX 3080/3090 graphics cards!
Thomas_S
Administrator
Alphacool today announces the first active backplate for Geforce RTX 3080/3090 graphics cards from Alphacool. The Eisblock Aurora GPX-N Acrylic Active Backplate is the perfect upgrade for Alphacool's Eisblock Aurora Acrylic/Acetal GPX-N GPU custom water coolers as well as Alphacool's Eiswolf 2 GPU All-in-One solutions. With the help of the backplate, the graphics memory on the back of Geforce RTX 3090 graphics cards can now also be actively water-cooled. With the help of 7W/mk thermal pads, the active backplate has direct contact with the graphics memory to be cooled and can cool it more efficiently. This results in a significant increase in cooling performance.
Like all products from Alphacool's Eisblock Aurora GPX acrylic product line, the active backplate also features brilliant illumination. Six addressable digital RGB LEDs are embedded directly within the cooler. The effect is an illumination that encompasses the entire cooling block and creates unique lighting effects. The digital aRGB LED lighting is connected via a JST 3-pin connector and can be controlled with a digital RGB controller or a digital RGB-capable mainboard.​
Active Backplate for Geforce RTX 3080/3090 GPU - general data
Material backplatecopper, nickel-plated
Material cooleracrylic
Threads Water cooling2x G1/4" | 2x 5/3mm tube connection
Illumination6x digital addressable RGB LEDs
MSRP79,99 €
1. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Reference
- Alphacool Eiswolf 2 AIO - 360mm RTX 3090/3080 with Backplate (Reference)
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 with Backplate (Reference)
- Alphacool Eisblock Aurora Acetal GPX-N RTX 3090/3080 with Backplate (Reference)
2. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090 Founders Edition
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3090 Founders Edition with Backplate
3. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3080/3090 Suprim X
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Suprim X with Backplate
4. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3080/3090 Gaming/Eagle
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Gaming/Eagle with Backplate
- Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Gaming/Eagle with Backplate
5. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3080/3090 FTW3
- Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 FTW3 with Backplate
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 FTW3 with Backplate
6. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3080/3090 Aorus Master/Xtreme
- Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Aorus Master/Xtreme with Backplate
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3080/3090 Aorus Master/Xtreme with Backplate
7. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3080/3090 ROG Strix
- Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 ROG Strix with Backplate
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 ROG Strix with Backplate
8. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 TI HOF
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 TI HOF with Backplate
9. Alphacool Eisblock Aurora GPX-N Acryl Active Backplate 3090/3080 Ventus
- Alphacool Eiswolf 2 AIO - 360mm RTX 3080/3090 Ventus with Backplate
- Alphacool Eisblock Aurora Acryl GPX-N RTX 3090/3080 Ventus with Backplate
>>> Complete overview active backplates for Geforce RTX 3080/3090 graphics cards
Depends on the main cooler. Because of the screw sizes they have. There are no real standards for it. You can see in the manual of the backplates what kind of screws we are using.
