• Dear forum members,
    Liebe Forenmitglieder,
    Danke für euer Verständnis.
New products: Alphacool ENTERPRISE SOLUTIONS T27 & T38 aluminium radiators
Thomas_S
Administrator
Alphacool today presents new radiators from the ENTERPRISE SOLUTIONS series. The ES T27 and T38 radiators, which are made entirely of aluminium, were specially developed for use in the industrial range. Due to the low construction height of 27mm or 38mm, they find room in the smallest of spaces and enable water cooling of technical equipment in the automotive industry, in mechanical engineering or in the production of films and videos.
High performance cooling! Compared to Alphacool's full copper models, all ES T27 and T38 aluminium radiators have additional cooling channels. This technical design allows a significant increase in cooling capacity without restricting the water flow within the radiator. The radiators have a high fin density of 20 FPI and are particularly suitable for use with fans with high air pressure and air throughput. This achieves a significant increase in the performance of the water-cooled components.
General technical data - Alphacool ES Aluminium T27 & T38 Radiators
Material cooling fins, cooling channels &
prechambers
Aluminium
Material outer housing & threadsAluminium
Fins per Inch19 (120mm fan) / 20 (140mm fan)
Threads2x G1/4“
Fan size120 mm or 140 mm
Max working temperature60 °C
Pressure tested0,8 Bar
ColorBlack
Variants:
- Alphacool ES Aluminium 120 mm T27 Radiator
- Alphacool ES Aluminium 120 mm T38 Radiator
- Alphacool ES Aluminium 240 mm T27 Radiator
- Alphacool ES Aluminium 240 mm T38 Radiator
- Alphacool ES Aluminium 280 mm T27 Radiator
- Alphacool ES Aluminium 280 mm T38 Radiator
- Alphacool ES Aluminium 360 mm T27 Radiator
- Alphacool ES Aluminium 360 mm T38 Radiator
- Alphacool ES Aluminium 420 mm T27 Radiator
- Alphacool ES Aluminium 420 mm T38 Radiator
