Hi , I've just received the EISBAER AURORA 420 and so far I'm impressed, however I wonder if you can clarify the following:
1) I have the pump speed set to maximum in the motherboard BIOS, is that optimal for cooling or should it be set to Normal ?
2) The Pump header is connected to the motherboard connector, will this be running at the full 12v ?
Thanks.
Thanks.
